Automatic centering?
#1
So I am trying to make a shell for a half sphere. I have made the two solid half spheres and now need to take the intersection to make the shell. Is there a way to auto center these objects along either x, y or z axis? Same for making things flush?
#2
Not sure I understand, can you post a screenshot?
#3
#4
When you are using the Translate tool, and selecting start and end points, it will snap to the center of the circular faces.
#5
Just tried and that does not seem to be accurate
#6
Yeah, I just tried a bunch and that is definitely not the case
#7
Hmm, if that’s a bug we will fix it with the next release, sorry about that. It should snap to the center.
#8
It would be nice if there were too also for vertical / horizontal alignment, flush or center along a chosen axis.
Then I could just tap object 1 then object 2 select x-axis then align center, and then the problem would be solved
#9
We have completely revisited transforming and aligning bodies, you will like it :slight_smile:
