Awesome stuff ! couple of questions with scaling
#1
First of all, I just purchased the pro app, and it is fabulous. Coming from sketchup i have to adapt a bit to the new way of doing things, but looks very impressive so far, especially on my new ipad pro 10,5".
I was wondering if it was possible at all to scale an imported image, for example a floor plan that I want to use as a base for my model. In sketchup you could import an image, click on 2 points and enter a distance, and it would scale the image accordingly… anything similar here that I’ve missed ?
keep up the awesomeness !
#2
Of course, when you import an image, you can set the exact dimensions with the white labels.
#3
OK, I get how you set the dimensions of the image itself, but say you have a jpeg with a floor plan, for example this one attached,
How can i make sure that the floor plan itself is scaled ? as it is smaller than the actual picture dimension ? Am i missing something here ? For example I know the dimensions of the basketball court, so how can I translate that in Shapr3D?
#4
For example you can draw a line with the given length, and scale the plan according to that. Or you can just cut the margin of the image.
#5
Ekiden, the way someone explained it to me once is that a jpeg like the one you posted here is not a drawing; it is only a picture of a previous drawing so there are no real drawing elements to work with. Hope that helps a bit.
