Bug List
Hi there. Just noticed an odd problem with an uploaded STEP file. I made the cog in Shapr - see second screenshot below and then uploaded a STEP file to Dropbox and downloaded this back into A360 to render the model - but the teeth of the cog were missing! See top screenshot . Have tried this twice but same thing has happened. I have checked in A360 but there are no hidden objects. If you want to see the file this is the link
https://www.dropbox.com/s/1pndw90egj28b9o/Cogs30.stp?dl=0
Have you tried it importing to anything else?
Have just tried importing the file back into Shapr and it is missing the teeth still - see screenshot below.<img src="//cdck-file-uploads-global.s3.dualstack.us-west-2.amazonaws.com/business7/uploads/shapr3d/original/1X/1bb58537abd5a88216b96190a0587263a545d446.png" width="666" height="500">
Just one further thought on this Istvan - the teeth were made by making a single tooth and duplicating it. I then joined all of the teeth together using the union tool. I wonder if there is something here to do with the fact that I duplicated a lot of objects? Andy
Really weird, I will look into this, thanks for reporting.
Not sure if I am the only one with this problem, but finding it difficult to draw circles at the moment! Just seem to get straight lines - pencil might be low on charge - not sure if this would cause a problem - is it just me? Andy
With the beta, or the live?
Well there you go - recharging the pencil seems to do the trick - feel a bit foolish for mentioning it now! Andy
Hi, just playing with the app.when I adjusted an arc to make it look tangent to a line the fill jumped from the shape to an invisible circle aligned with the arc. Is this normal?
I undid it and got it to do it again too.
That’s a bug, thanks for reporting it. Such issues can occur when two curves have very similar tangents at their start points. That’s a known issue, we just did not have time to fix it before the new release, but we will fix it in the next release.
