Group management: naming a group
#1
I found that when I change the name of a group shapr sets by default a name “process”. Then when I change this name in “name1” it is ok.
#2
Hey!
Thanks for reaching out. Are you using the latest version 3.0.4? We had a bug in an earlier release but this should be fixed now.
#3
Yes, latest version.
I cannot replicate the issue every time…
#4
Hi Joost - we will look into it. As Tibi said, this should be fixed but we will try to replicate it.
#5
If you could give us any specifics on what you were doing when this issue happened that would be much appreciated. Thanks!
#6
This is the name of the group which is “generated” by shapr: v@:q@?
I cannot change tha name anymore.
I also include the shapr file: “vaankop9”. (This is a 3d part to be printed for a “windvane selfsteering device” on my yacht)
Best regards,
Joost
vaankop9.shapr (1.61 MB)
#7
Thanks Joost, we will look into it!
#8
Thanks for your help Joost, the bug has been found and killed. You’ll find the fix in the next version (3.0.7, coming around next week)!
#9
Same with me. I have that same issue!
#10
We have successfully reproduced the issue, it will be fixed with the next release.
