How do I resize a group
I found a previous post on this but it’s closed and the solution only suggests I use “the yellow things…”
How do I resize an imported object? The object is imported as a group but I don’t see a method in “transform” to modify the group size. Is this possible?
yes - you have to use the yellow thingy :slight_smile:
You can reach it at
  1. Transform/Freeform
  2. select a Group on the top left
  3. use the yellow arrow, after selecting the group
See video below for better understanding (I also included a pivot point version in the second part - it helps you scale in a more controlled environment):
That’s it, thanks!
