Moving a simple shape
#1
I’m hoping I’m just overlooking this simple function. If I draw a circle and want to simply move it a few mm in one direction, I thought I could just do this by selecting the circle and dragging it into position with the pencil (see 13:25 in this tutorial video: https://youtu.be/OFsbZikomSA). However, I don’t seem to be able to move the circle after drawing it. I have to use the free form transform tool which seems excessive. If I tap the circle and try to move it all that happens is another line is drawn.
How do I move a shape with the pencil by dragging it around?
#2
Select the sketch with the pencil. Then you can simply drag it’s points to position them.
#3
So it’s not possible to grab a circle shape and drag it at its current size to somewhere else in the workspace? I’ve figured out that I can change its radius and circumference by dragging the two points that appear when you tap it. Several of your tutorial videos though show the whole circle being moved as one to reposition it. That does seem much more intuitive. Has this changed?
#4
If you lock the radius of the circle, then if you drag a point of the circle it will move the circle. Otherwise (since the circle is defined by two points) you will change the position of one point, and the circle will be recalculated from the points.
#5
Makes perfect sense. Thank you.
#6
However woth the next release this is going to change, and when you drag a selected sketch, it will be moved, instead of being extruded.
#7
If I may just add a thought to this discussion:
… It would be very helpful if a circle could be selected [for Transform/Translate operations] by its centre.
… and, incidentally; the ability to select a line by its midpoint would also be convenient.
MichaelG.
[as a new user, I may have ‘missed a trick’ … if so, please educate me]
#8
Works for a simple circle b/c you can select/lock radius, but how do you simply move an entire extruded shape? I can see no easy way to do this other than ‘transform’ which is not a simple process. I move shapes, parts, etc. constantly and it seems there should be a way to intuitively grab and drag these shapes I’ve created. Am I missing something? Can’t find a tutorial for this?
#9
There are 4 different ways to move an object:
  • general transform, using the gizmo (arrows and rotation arrows)
  • translate tool (by defining a start and end point of the translation)
  • rotate tool (by defining an axis and an angle of the rotation)
  • mirror tool (by defining the plane of the reflection)
There is no other way to move an object in Shapr. What you want is unfortunately under-defined, since you it would require moving an object in 3D space on a 2D screen.
#10
Thanks - transform/translate works, but it seems very imprecise. How do I pick fixed coordinates to move the shape exactly? Or failing that, How can i grab a shape and hover with it until I can place it where I want it? (I do this in Sketchup rather easily)
Also, I find it’s a bit the same with drawing shapes. It would be ideal if shapr had a rectangle function instead of having to draw 4 individual lines. (?!)
And if I could snap an additional, smaller rectangle to the same starting coordinates, i could really make better use of the extrude function.
I realize Shapr is not Sketchup, but these things are easy in SU.
I like the app, but these are the deal breakers for me when it comes to buying a subscription. Thanks again for your help.
#11
OK - my bad, I think I got it, you have to double tap screen and transform in 2D, and then you can pinpoint where to move shapes and then pull back to 3D to view. It’s certainly not intuitive, but works very well.
#12
Take a look at some of the things I have created. I use both the transform and translate extensively. With the translate feature being the most widely used by me. It is extremely precise and I think that it is really straight forward to use.
What is it that your having troubles with? Maybe I can assist with a video, although I picked it up right from the tutorial video that the app provides.
#13
Figured it out thanks. See my last post. Thanks anyway
#14
Your welcome. Let us know if we can assist. Sometimes a video from a different perspective helps.
