# 5.460 - Base and Projection views in 2D Drawings
**URL:** <https://discourse.shapr3d.com/t/5-460-base-and-projection-views-in-2d-drawings/27719>\
**Category:** Release notes\
**Created:** [September 11, 2023, 11:25am UTC](https://discourse.shapr3d.com/t/5-460-base-and-projection-views-in-2d-drawings/27719 "2023-09-11T11:25:31Z")\
**Showing post:** 24
**Author:** ![Alexander\_P](https://sea2.discourse-cdn.com/flex002/user_avatar/discourse.shapr3d.com/alexander_p/32/9694_2.png) [@Alexander\_P](https://discourse.shapr3d.com/u/Alexander_P)\
**Post date:** [September 18, 2023, 7:54am UTC](https://discourse.shapr3d.com/t/5-460-base-and-projection-views-in-2d-drawings/27719/24 "2023-09-18T07:54:13Z")
Hi Larry,
The option is still there just moved to another place. You can find it when adding a new base view. If you click on the orientation badge it will offer the possible base views for selection and there you will find the button to change which bodies should be added as a base view.
 ![Screenshot 2023-09-18 at 9.51.17](https://us1.discourse-cdn.com/flex002/uploads/shapr3d/original/3X/2/3/2352bffe6551aac9820530f143439638b5faf21e.jpeg)
_[View the full topic](https://discourse.shapr3d.com/t/5-460-base-and-projection-views-in-2d-drawings/27719)._
