Add construction plane function
Even if I already have a whole list of wishes, I still write my experiences, and again I miss a function that I found useful :grinning_face_with_smiling_eyes:
Since I often design from the zero point and otherwise often use construction surfaces that correspond parallel to the x y z axes, I missed such a function.
It would be nice if, after selecting “Construction plane type offset”, I can either select 2 suitable axes or the appropriate view on the cube and then, as usual, choose an offset if desired.
See photo.
