Are there any plans to incorporate Shaper3D compatibility with ANSYS software? ANSYS allows for IGES files to be imported, but when I do it does not work properly where the solid model does not load, only the outlining lines show up in place of the actual model to be tested. From my small amount of research, those sources said to use SolidWorks.
Hi, I’d strongly recommend not using IGES format for data exchange. Most likely that is causing the issue. Try to import the same model in X_T or STEP formats to ANSYS.
