If I try to save a design using an emoji, I can’t delete the emoji
Thanks for the report, we are fixing it.
Also just a couple of suggestions:
- if I need to transform several objects individually, I’d like the transform tool centered on the next object when I select it.
- I’d also like a function to Centre an object in the workspace ie xyz 000 using a button tap.
