# Chamfer and "no blend" error
**URL:** <https://discourse.shapr3d.com/t/chamfer-and-no-blend-error/38453>\
**Created:** [June 19, 2025, 3:17pm UTC](https://discourse.shapr3d.com/t/chamfer-and-no-blend-error/38453 "2025-06-19T15:17:21Z")\
**Showing post:** 16
**Author:** ![SCALEMODEL](https://avatars.discourse-cdn.com/v4/letter/s/77aa72/32.png) [@SCALEMODEL](https://discourse.shapr3d.com/u/SCALEMODEL)\
**Post date:** [June 20, 2025, 10:09pm UTC](https://discourse.shapr3d.com/t/chamfer-and-no-blend-error/38453/16 "2025-06-20T22:09:08Z")
So are you saying Control Splines are Bezier Curves?
I call it B-Splines (oh B not for Bezier) or Nurbs.
Got into that here because of export issues.
> [@SVG Export results in a bunch of straight lines](https://discourse.shapr3d.com/t/svg-export-results-in-a-bunch-of-straight-lines/38431/15):
> That Control Spline issue looks like what the Original Poster was encountering. I kinda know why, Control Splines are NURBS Curve. Fit Spline is more like Bezier Curve. AI and Affinity Designer don’t have built in NURBS Curve so it looks like it’s converting it to segmented curves with high resolution. So as far as I know only software that can convert Control Spline Correctly is RHINO to PDF. If others have better conversion method, please post.
_[View the full topic](https://discourse.shapr3d.com/t/chamfer-and-no-blend-error/38453)._
