Construction Axis 2 Points
I want to add a Construction axis between these points.
F6D9D5E6-77C8-4E27-80F6-F7065C078A8F
But they disappear in the addition interface? What to do?
36717389-41B1-4777-80D8-46786F73737B
That’s a very interesting observation. Btw, the points should still snap to the points of the sketch.
You are correct and it worked by memorizing where the point was on the grid. If one is not careful the point could go anywhere.
CC607151-8926-4969-B9D8-5AB384A5F473
I can’t seem to draw a normal line between two construction lines and get any sort of snapping however. Also I can’t seeem to draw a construction axis between two points on other axes. Points do not seem to be recognized?
Thanks,
