Delete all constraints of an imported DXF?
Hi there, i have recently imported a logo in DXF format, i want to scale it before i extrude it as i want to set my height as 25MM therefor i want to scale the sketch first, then extrude.
When i try to scale it says the error message ‘transform failed because sketch constraints could not be solved’ how do i remove all constraints at once?
Alternatively i can just extrude, scale and then drop the height back down to 25mm.
Matt
All sorted now, i managed to select the sketch as a whole and disconnect :smiley:
