# Export designs not possible
**URL:** <https://discourse.shapr3d.com/t/export-designs-not-possible/6111>\
**Created:** [November 27, 2019, 8:14am UTC](https://discourse.shapr3d.com/t/export-designs-not-possible/6111 "2019-11-27T08:14:02Z")\
**Showing post:** 26
**Author:** ![Istvan](https://sea2.discourse-cdn.com/flex002/user_avatar/discourse.shapr3d.com/istvan/32/23668_2.png) [@Istvan](https://discourse.shapr3d.com/u/Istvan)\
**Post date:** [December 13, 2023, 1:12pm UTC](https://discourse.shapr3d.com/t/export-designs-not-possible/6111/26 "2023-12-13T13:12:14Z")
> [@The share function on ipad is completely out of order](https://discourse.shapr3d.com/t/the-share-function-on-ipad-is-completely-out-of-order/27855/7):
> This sounds like the same persistent OS bug that has been around caused by the Siri suggested sharing options. This used to happen to me. I do not have WhatsApp, however I would still have the issue. And it was intermittent. My fix was turning off the Siri suggested sharing: Settings\>Siri & Search\>Show when sharing\>OFF You may need to restart your iPad after. Although you won’t have the convenience of the suggested sharing, you should be able to share after turning off suggested sharing.
_[View the full topic](https://discourse.shapr3d.com/t/export-designs-not-possible/6111)._
