Continuing to use the software and going through fast iterations of my designs for 3d printing I find myself wishing for a “commit-on-export” functionality. I could do it manually by making the project folder a repo and commit manually, but really if Shapr is targetting proffesionals it should provide a simple way to use versioning systems.
Also, saving should be simpler. There should be a workspace folder in which project folders are created on project creation, named after the project name and initialized it as a repo (if git integration is available and enabled). From there on, a simple Ctrl-S or equivalent should save everything there and offer to commit, accordingly.
I’ve used Shapr for about 2 months now, both on iPad and MacOs, but I can’t find where the designs’ files exist unless I manually export the them.
Hi Josal, this is definitely something that we are interested in. Would you like to use git for collaboration as well, or only for version control?
Also, can you elaborate on what you mean by saving? Saving is done completely automatically in Shapr3D, since under the hood we have an SQLite database, which is updated automatically.
Collaboration over git sounds like a great feature! It’d make sense to get an integration with git first, and then add the extra feuatures at a later release.
Saving in the database, is it for speed? Even if so, the db only needs the latest snapshot of the project, but saving into the file system is also worth, both for redundancy and for versioning.
