Feature Request - Merge two different workspaces into one
#1
FEATURE REQUEST - Merge two different workspaces into one . This would likely eliminate the issue I am seeing. I frequently work a portion of a model in a different workspace to avoid accidental changes to work that is near final result.
#2
It seems I just stumbled on this, it already works, with an extra step. :sunglasses:
Save one of the 2 workspaces as a SHAPR file. Now open the other workspace as your active workspace. Then choose the saved SHAPR file from the files app and choose the copy to option, it will ask if you want to copy it to the open workspace or a new one.
When it completes you will have both workspace bodies in one.
