How to import NACA airfoil coordinates to shapr3D?
Hi, I wanted to know if it is possible to import coordinates from NACA airfoil into Shapr3D
Thanks in advance
Hi, you can model your aircraft components in Shapr3D and then export the file to Solidworks or Ansys in STEP or IGES format, which supports importing Airfoil coordinates.
Currently this is not supported by the app. Thank you for your understanding.
Some airfoil program can draw the foil in dxf format from dat file (for example profili) then you can inport it to S3D.
