# How to loft around a path
**URL:** <https://discourse.shapr3d.com/t/how-to-loft-around-a-path/8350>\
**Created:** [July 17, 2020, 5:38pm UTC](https://discourse.shapr3d.com/t/how-to-loft-around-a-path/8350 "2020-07-17T17:38:17Z")\
**Author:** ![Gelphyn](https://avatars.discourse-cdn.com/v4/letter/g/db5fbb/32.png) [@Gelphyn](https://discourse.shapr3d.com/u/Gelphyn)\
**Post date:** [July 17, 2020, 8:57pm UTC](https://discourse.shapr3d.com/t/how-to-loft-around-a-path/8350/2 "2020-07-17T20:57:24Z")
Hi @slugbut Wellcome to the Forum.
Use **Sketch \> Line/Arc** to create an Arc, alternatively use **Sketch \> Spline**.
In the following **Add \> Construction Plane** \> choose Option - **Perpendicular to a Curve**.
Tap on the Curve [Arc in this case] at this stage the Construction Plane can be dragged along the Curve.
When there are sufficient Construction Planes choose one at the end of the Arc and Tap on it with a Finger.
This will move the Construction Plane and display a Grid ready to accept a Sketch.
In this case Circles were used.
Hiding Construction Planes and their Sketches, will improve access to the Plane Sketch in progress.
Sizing the circles appropriately can provide the shape required.
**Tools \> Color** was used to make the ‘tooth’ transparent to show the construction:
 ![IMG_2152](https://us1.discourse-cdn.com/flex002/uploads/shapr3d/original/2X/4/47ce1297a3b8eb3d6a9bfb40c0b6a129cdafa4b9.jpeg)
Set up your Design Scale appropriately [I quickly drew this without paying attention to Scale]
This may offer some more help:
[https://discourse.shapr3d.com/t/combine-loft-and-sweep-tool/5988](https://discourse.shapr3d.com/t/combine-loft-and-sweep-tool/5988)
Shout if you need more help.
Happy S3Ding.
_[View the full topic](https://discourse.shapr3d.com/t/how-to-loft-around-a-path/8350)._
