How to model a canopy (see pics)
#1
Like the title says, how would one go about modeling the below image? I created a side profile of the rough shape. But can’t figure out how to model this.
Anyone try something like this? This is hollow and will fit over the helicopter I am working on. But Incant seem to figure it out.
#2
Sweep and cut from side
#3
Thank you, however I’m Not sure I understand how.
Here is the SHAPR FILE with the side view sketch.
Canopy.shapr (4.7 MB)
#4
I wanna show you but I do not know how to record my process.
#5
Thank you.
If your using iOS 11 or newer there is a built in screen recorder. Here’s how to enable it.
#6
Uploading: 01AD8C6E-54C8-45E7-9A16-D5288DF7911E.jpeg…
#7
#8
#9
I will have to give that a try. Not sure I can get the shape I want though. I did try loft but from the side rather than front to back.
#10
That is also what I used with PTC CREO except 4 edges surface.I think It works,but you need to adjust your section again and again.
#11
That is my achievement,I definitely certain It is not what you want,since it is not under your dimensions😊
#12
Better than I did. I don’t even have dimensions. I was going to model it to closely resemble what I’m looking for then use the scale feature to get it close, then adjust as needed. Unless of course there is a better way to do it.
I don’t do well with these types of shapes. I am better with mechanical type modeling.
#14
This is much similar to a project I did in the past, I’ll share it here so you could take benefit from.
canopyLike.shapr (4.7 MB)
#15
Thank You for sharing this. I will take a look a little later and see if it will help.
#18
@hamedtopic I haven’t had a chance to look at this as I got really busy yesterday with work and I am pretty busy this morning already, hopefully this evening or possibly tomorrow I can take a look. Sorry for the delay in getting back to you.
I appreciate your feedback and the time to share this.
#19
No problem, have fun!
#20
So, I’ve taken a look at the file you shared. It’s a similar idea but I am not certain it will help. I will play around with it and see what I can come up with. Thanks again for sharing it.
