Inability to Display Simple Dimensions
I have a simple 24’ x 26’ rectangle which is a Top view sketch of my building. Pretty simple! I need to be able to take a screen shot with both dimensions. Unfortunately, after trying everything, I am unable.
This seems to be a basic capability. In the prior version, there were too many dimensions but now not enough. To be truly useful for architecture where a sketch is used to build something, the display of a dimension should be user selectable.
68B9BAD0-942E-4F9F-9A5B-BBB0141453F86803DF47-02BD-4DEE-BC1A-4731A0F089C2
Thanks for looking at this.
I have no problem with this.
You need to lock the values first.
Yeah, lock the length and not the points :wink:
@tommyn with the new sketch engine, in 99% of the cases you won’t have to lock your points, because the new engine will move the minimum number of geometry.
I am only saying this, because I understand that our previous engine probably caused PTSD for you, and now you still want to lock everything, but don’t worry, it’s gone :slight_smile:
Mea culpa, mea culpa, mea maxima culpa; LOL.
I was switching back and forth between the two versions a lot so my mind may have been befuddled. Duh!
