Maybe not a bug, but... Pressure sensitivity for spline points
So for a while I wasn’t able to add any of the control points (fit) for a spline curve, but then noticed the light/hard setting and switched it to light and it now works fine, which makes me wonder
1 - was I not pressing hard enough (I think I was, the screen was distorting)?
2 - is my Pencil not registering the taps hard enough?
3 - is the software threshold too high?
I’m not blocked, but has anyone been actually able to add points on high, and does anyone know of a simple app to test the tap pressure values?
Hi, at times that happens due to a temporary glitch from the app which can be resolved by reloading the app.
To help our investigation, please reload the app, switch back “Pencil pressure for point placing” to Hard and let us know if the issue persists.
Thanks for your time and I will be looking forward to hearing from you.
ok, that did it. Mystery solved.
