Move imported images
I have an imported image with a 50% opacity, but when I move the image to adjust it in its final position it becomes 100% opaque and I cannot adjust it correctly. You can modify this opacity change so that it is maintained once selected.
Hi David,
This only happens when you select the image, to enable users to properly reposition the image in cases where the image is almost transparent.
When you deselect the image, it’s then displayed at the set opacity level and can be used as a trace outline for making your sketch.
good afternoon Victor
I meant just the opposite, to keep my opacity to reposition the image when I have an object just behind as I show in the previous images.
Hi David,
I see what you mean. I will pass on your feedback to our product team and thanks for your understanding.
