has someone a direct comparison (if someone owns both) of the iPad Pro 11" 2nd Gen (A12Z Bionic) and the newer one with M1 chip? I just noticed on mine (A12Z Bionic) a bit of lagging when it comes to visualization mode and larger (and detailed) sketches.
As far as I know, both models use the same amount of RAM (8G on models with 512GB or less storage space). And also - as far as I know - per process memory is limited on iPad OS anyways - has this changed for M1 version?
Also, there are tons of reports on M1 devices (iPad, MacBook) randomly/frequently crashing - has anyone experienced this while working with Shapr3D on a iPad Pro 11" with M1?
The memory limit is lifted in iPadOS 15, if the application supports it (we do). The previous limit was 5GB RAM usage / app, which didn’t matter much, as the most you could get was 6GB RAM, as the previous gen maxed out at 6GB RAM, while the M1 has 8 at minimum, and 16 max.
Am I reading it correctly? So the limit is completely liftet? And Shapr3d have full access to the 8 and 16 GB ram of the ipad pro m1 ?
Edit: This is from september but it by the looks of it you get full access to 12GB of ram (and 6 on the 8gb) but the remaining 4GB will be a buffer for other things?
