If I almost exclusively mean “Add Plane - Offset” when I type “add”, Shapr3D should default to this action, instead of ALWAYS erroneously suggesting a million things other than the command I always use.
Thank you. Love the program.
When you select items, Shapr3D only suggests the functions that can be performed with them.
The arrangement of the choices such as the way of adding a level should remain as you can choose it in the dream because it doesn’t change.
If the order of priority changes or the last selection used, you always have to read this reassignment because it changes, which is very tedious.
As it is now I find this very efficient.
You could maintain the exact same menu, in the same order, but have a single, additional, best guess at the very top.
