This would help if you could
Use a construction plane to slice through a solid to create separate parts.
Have more functionality options with the Intersect tool.
Less problems when trying to change to a 3d view after you have double clicked on a surface, it keeps reverting to the surface view unless you do a big a finger swipe which can take you a distance away from the area you are trying to view.
If you could have an easier way to delete multiple sketches within the folders area especially when you have imported a file.
Edit an imported file more easily as most imported 3d designs created outside Shapr3d have limited use unless you can edit them.
If it took less time to import an external file.
Have more surface creation tools.
Great program though, thanks.
