Unable to export as STL file
h076b np-fw50 reverse.shapr (6.5 MB)
I have re-edited a file I created some time back which I had exported as a Shapr file AND as an STL file. However when I re-edit (I ported as Shapr file) it I can export it as a Shapr file again. But I am unable to export as an STL file.
I receive and error which says nothing has changed and then an indefinite spinning wheel and have to close the app and restart to continue.
Even if I import into a new session the file I had just exported (as the Shapr file) I am Still unable to export to STL.
Any suggestions on how this may be fixed?
Cheers
Kim
Hi Kim, there are quite a number of invalid faces on the model and that’s the reason the STL file format export fails.
Here’s an example of one of the faces:
I have tried to fix the design but the issue persists as I find more invalid faces
Please give us some time to see if we can help fix the model
Thanks Victor.
The original model was imported by way of a Thingiverse stl file conversion into a mesh tool (don’t remember which), into shapr.
But I am intrigued as to why it fails this time around, when the only changes were to delete the parts I added last time and re add them on the opposite side.
But this was done pre the availability of the STL import capability. So I might retry it by directly importing the STL file now and then adding my extra bits.
I’ll do that now and that should save you a fair bit of mucking about (hadn’t thought about that earlier).
Cheers,
Kim Shapley
kshapley@bigpond.net.au
0400162451
Thanks Victor,
Importing now with the original Thingiverse STL file worked fine (instead of the converted mesh). I can modify and save OK as an STL again.
Cheers,
Kim Shapley
0400162451
Hi Kim, it’s great to know that it works now.
If you have any further questions, please do not hesitate to reach out.
