Trim Function
#1
It would be nice if the Revert icon worked while in Trim. If you make an error and trim something important after a long series of other trims, one is somewhat screwed as there is no Revert or Cancel; only Done.
Unless I am missing something here?
Yes, that’s a bug. We’ll fix it.
After you tap Done, you can use the Undo (Revert) button as of now.
