Faint Lines in Body
When drafting a body, often times these lines appear. What are they? There seems to be a correlation when these lines appear that the file will translate in Fusion360 as a distorted hollow body.
I have never seen that before in Shapr3d, does those lines go away when you rotate the camera? Also looks like a video card glitch, graphical screen tearing. Are you saying these small seethrough strips carry over to Fusion? Since you activated the Section View do they go away when you go back to the normal view? Maybe a reboot? You can share your file here someone can open it and check it.
Have a look in the visualizer. See if they are there.
…I don’t know how to do that.
Not at my dev machine,but it should by an icon near the top, This many help.
https://support.shapr3d.com/hc/en-us/articles/7874459464092-Visualization
Hi, to get assistance, please submit a support request using this link: Shapr3D Support. Make sure to include your design exported in .shapr format, and the hardware and software specifications of the device that you are using. Thank you!
