Hi!
I’d like to know if there’s any feature to unfold faces of an object like in sketchup. For example, I’m designing a packing box and I would like to flat the project to cut it in a laser cutter.
See video below:
Hi!
See video below:
Hi, this is currently not possible in the app.
If possible, you can simply create the flat surface sketches for the box which can then be exported in DWG/DXF format for the lasser cutter.
