Grip Head
Some shots of a commonly used piece of film grip gear I modelled.
Great work :star_struck:. To be curious, what is it? And for what it is used for ?
Thank you. It’s a key piece of grip equipment used in film and tv production. It’s essentially a link between a fixed point and any one of literally hundreds of different elements used to shape light or hold other film equipment. I’ll be posting more here that will show some examples of it in use, but it’s also called a Gobo head if you want to look it up.
it´s great grip.
is there anywhere to download/buy model?
Sure you can have a copy of the model, what format do you want it in?
obj will be great =D, thank you very much
Grip head for export_OBJ.zip (10.2 MB)
Could I ask you one more time for some cad format? I tried to close the holes to insert the nuts but I have a problem with the obj
Thank you very much again.
How can I 3d print this?
With a 3D printer?
Peter J. Morris
By Hand & Hammer Stagecraft Inc.
(250) 413-7939
The 3D printer is the Ender 3v2
Are you asking me if you can have access to the 3D model? If so, yes but I promise you it’s cheaper to buy the original item rather than print it, and it needs to be very strong to do its job, they are made of aluminum or steel, depending on the brand.
Peter J. Morris
(250) 413-7939
That would be great! I was hoping to save almost $60 and print something on my 3d printer that could manage to hold a small scrim. Thoughts?
For a small scrim, you don’t need a 2 ½” grip head. Kudos makes a pretty nifty little mini head. The thing is, grip heads are the catastrophic fail point in any lighting set up, you don’t want to go half arsed. All grip heads are tighten to the right, loosen to the left, for good reason. Also, this model was not built for manufacture, it was built for components in an animation.
Printing metal design with 3d printer plastic your bound to suffer catastrophic fail, I have learned my lesson. If you do want to 3d print you really want to thicken and reinforce it.
