Hi all. I imported a drawing on A4 paper. The size of an A4 paper is 296mm x 210mm. When i enter the size 296 for the hight the width autmaticaly adjust to 214.918. If inchange that to 210 then the hight automaticaly goes to another value. How can i get it width 210 and hight 296?
you can use scale in non uniform mode on the transform menu, to achieve this.
1/ sketch a rectangle of the target size
2/ move the image so the bottom left corner is located to the bottom left corner of the rectangle
3/ use scale in non uniform mode, to adjust independently width and height
Short video to show it.
