Question about sweeping along multileg path
when using sweep along a path that is made out of several sub-parts (lines, curves etc., all connected!!!) the resulting body shows black lines where the connections in the path are. Can that be changed?
If you do multi segmented sweep, if it wasn’t a continuous line without breaks you get those disconnected lines, I don’t think you can get rid of it and as long as the lines don’t show up in Visualize mode its ok.
So could minimize those lines if we had Real 3D sketch with fully continuing lines like in Rhino3d.
Sometimes I do 3d Sketch in Rhino and export/import as IGES, it brings in as sketch.
That’s a very clever idea! Thank you for that!!
