is there a limitation of the size of a model you can have a section view.
I have modeled a house and I can’t have a section view, it gives me a projection failed error.
my best,
Je
my best,
Je
Hello! There is no limitation set, the issue must be something else. Could you please share the Shapr3D Design with us at: https://support.shapr3d.com/hc/en-us/requests/new
I’ve tried to use the old method by projecting on a plane to export as a sketch.
but it fails too.
here is a video capture
and here is the file
SesPares 23_20220110_Attico.shapr (7,6 Mo)
Thanks,
I think the projection and sectioning issues are two different cases. The model you have uploaded is a much simpler one, it can be sectioned. Projection fails I can confirm, let us investigate it.
In the meantime, if you could send us the original file by opening a support ticket, I’d be happy to check why sectioning fails.
Hi Peter,
I have opened a support ticket with the original file but as you can see in the video I add I have failure to section this model too
my best
Thanks, I will have a look at it!
