Shortcut key for Toggle Construction Lines
Of all the operations I perform, Toggling Construction on a Line is one of the most common without a shortcut key. I would love to have a faster means to access this “constraint”.
Thank you!
This is a great idea. I propose that Shift-K (maKe construction / maKe regular) as the keyboard shortcut to toggle this property.
This is the most annoying thing, sketch, line, draw, convert and there is no shortcut.
Can we just have a line time of construction some can just sit there and draw up our framework in construction “mode” straight up?
Hold shift while drawing for it to be construction?
[Key]+K to toggle last line or selected?
We are introducing custom keyboard shortcuts soon, so you’ll be able to set the shortcuts for yourself.
