Hi, I am using the beta version on IPad. Once you split a body, the delete one part and Mirror the other part, the Union command of those mirrored bodies fails. It claims “the boolean operation failed”. Any hint or a beta bug? Thanks.
Hi @flarecz ,
My guess is that if it did union, you’d get a non-manifold body, and Shapr3d won’t do that. This type of failed Boolean is not because of mirror then delete, but due to the geometries of the two bodies. Can you attach a screenshot?
Thank you very much for your feedback, really appreciated!
