26.50 - Advanced Section View controls
Isolate your cross-sections and maintain your perspective with more precise control over Section View visibility and alignment.
  • New: Now you can use the Section Only mode within Section View to hide all model geometry and focus exclusively on the cross-section.
    26.50-section-view
  • Improved: Toggle 2D view (formerly Ortho View) to display the cross-section and visible background edges and silhouettes for better depth perception. When you rotate the camera, you can now use the Normal to Section option at the top to instantly realign the view without leaving the mode.
    26.50-section-view-silhouettes
  • Improved: The Wrap & Emboss tool now includes a gizmo for rotating your design and adjusting emboss depth directly in the modeling space, giving you visual control alongside the tool card parameters.
    26.50-wrap-emboss
Try these improvements and share how they help you with your workflow in the comments below.
Excellent! Being able to flip the wrap orientation is a big help!
