Adding Text to Curved Surface (Projection Failed)
I am attempting to add text to a large cylinder that has the rough appearance of a hockey puck. I would like the text along the vertical (curved side) of the cylinder, but when I try to project the text onto the cylinder it says “Projection Failed”. Is there another way to get this accomplished? I’ve followed a few tutorials and I can’t seem to get them working either.
Sorry for misspellings :slight_smile:
Just played a little bit :slight_smile:
Hi, I’ve tried the same and can’t get my text to wrap around the curve. After watching your video many times I noticed eventually that the first and last characters are stretched out, so does it wrap or it’s just that your text is short enough that it fits on about 1/3 of the circumference?
Method on the video doesn’t wrap text but just project it on surface.
You can wrap text around the object using another method - manual placement. The result you can see on the photos below the video.
Thanks. I kept trying with a long piece of text and just couldn’t get it to get the same result as you! :slight_smile: Pity one cannot ‘sweep’ text along a path even if it is restricted to 2 dimensions.
Shapr needs a Wrap Tool.
This is easy to do on Onshape
Just had a look at OnShape and seems to have all the functionality of Shapr3D and as you point out, more … it has threads! Sketch functions are similar with constraints, it’s cloud based with versioning, parametric (so can edit dimensions), has full featured drawing tools, works on most platforms including iPad. And, for the hobbyists, the free version appears to be unrestricted in storage and exports (for non-commercial use and designs are public).
