Align cylinder to construction axis
Please add capability to align a cylinder or cone to a construction axis.
See this discussion:
Currently this alignment requires a fair amount of work. We currently can align a planar face to a construction plane; this would be similar, but for cylinders and cones to align to a construction axis.
This feature will save time when needing to align a cylinder to an arbitrary construction axis.
While not a blocker, the current method is awkward.
I agree and would like to +1 this request. Any face should be alignable to a construction axis.
Use case: After importing a model with a hole on a complex surface, how to create a countersink?
One way is to create an axis using the cylindrical hole. But after that, the current state of affairs feels … unsatisfactory. I’m bumbling around trying to figure it out.
I found another align method.
While making that video I discovered you can project Construction Axis.
So another method.
Ok after doing examples above.
Another scenario came to mind!
What if you imported a square with a hole how would you align that property with the axis?
