I need to print my sketches to use as a template for my designs
Hi, you can make screenshots of the sketches and then use the iPad markup feature to indicate the dimensions.
It can be printed as an image file or converted to PDF using a free online converter.
For printed hard copy size, this is more printer-settings related.
I’m using the OS X beta version of Shapr3D and have the same question.
how do I print to an inkjet printer at true size?
I want to compare the model to the target device (a film scanner adapter) before sending it to a 3D printer (which costs money $$).
cheers
Gregory
