Area selection in Sketch mode 5.520 beta key bindings
When using area selection In sketch mode, keyboard entry “E” does not filter selection to Edges. The other keys work OK. (P->Points, C->Constraints)
iPadOS 17.1.1
Shapr3d beta 5.520.0.6107 #9a56fc4a
iPadPro with Apple’s Magic Keyboard.
@Bob3DPO indeed, for some obscure reason the filter shortcut for sketch edges is S (probably at some point we called the filter sketch edges). Will change it to reduce confusion, thanks for reporting.
In 5.520.0.6133, the key binding is good, where typing E chooses the Edges filter, thanks.
However, I cannot select edges from sketch with area selection. (I can select faces from sketch.)
My use case is I would like to select edges (whether or not they make a closed face) and project them.
Seems this key binding was reversed. In 5.521.0.6218, the S is bound to edges in sketch mode, not the E. Is that by design, or a regression?
No, it’s just a temporary regression – the fix got lost amongst the code branches between 5.520 and 5.521. It’ll be OK again in the next regular release. Our apologies.
