On an iPad, could you please, when selecting an item by double tapping it it gets selected on the all items list and brought to view instead of having to scroll a big list and going through folders?
You can select drag (area select) like on PC. Hold the stylus down and a half blue half purple ball will appear. Then when you select the area, 4 options on the left will appear for body edges etc. in sketch mode those options are different too.
Edges like a gear with beveled teeth is a lot easier then selecting all the tooth edges
