I’m using the Fill tool to recreate this hairdryer-handle-like model, but the two sides came out asymmetric. My sketch and the top/bottom bodies were drawn symmetrically, so I’m wondering what’s going on — or is this a known bug? Model file attached.
model.shapr (143.1 KB)
The side lines aren’t symmetrical. Once I made them symmetrical, I got the expected result.
model.shapr (178.3 KB)
but my edge lines were created by mirroring, as can also be seen in the video I uploaded. It feels a bit strange, so I’ll try again later.
There’s definitely a bug here. I’d recommend submitting a bug report about this issue.
Thank you for the feedback! Our developers checked your model. One of the guide curves did not connect properly to the input network, so the surface fitting algorithm ignored it completely. That is why redrawing the guide curve resolved the issue.
I went back and double-checked my model — turns out the original body I built wasn’t symmetric to begin with. So even though I mirrored the sketch afterward, it never lined up with the model. Thanks for your help!
I suspected that, but didn’t check.
I went back and double-checked my model _turns out the original body l built wasn’t symmetric to begin with. So even though I mirrored the sketch afterward, it never lined up with the model. Thanks for your help!
Yes, exactly — the root cause was that I hadn’t built the model symmetrically from the start, so that’s what caused it. Thanks for your help!
