AVX2 Instruction set
Just opened Shapr and this screen shows up: does it mean I won’t be able to use Shapr any more on this machine (it does not have AVX2)??
How about the possibility to keep a Shapr Version that still works on this machine? Is there a way? Otherwise I’ll have to buy a new PC only because of Shapr3D? I understand obsolescence, but Shapr still runs perfectly fine with the current hardware, let me choose when I want to buy a new machine, don’t force it on me!
Hi, can you please open a support ticket here with the following information?
  • email address connected to your Shapr3D account
  • The version of Shapr3D you are using as shown under your Settings
  • The detailed hardware and software specs of the machine you are using: Find hardware and software specifications
Thanks!
I already opened a ticket yesterday, the other informations you requested are here:
  • email connect to Shapr account:
  • Shapr 3d Version: 5.950.9502.0 #1d5f0d29
    -detailed hardware and software specs: in the DxDiag.txt file attached here.
(Attachment DxDiag.txt is missing)
  • detailed hardware and software specs: in the DxDiag.txt file attached (zip format) here.
Best regards,
(attachments)
DxDiag.zip (14.8 KB)
