Can Someone make this for me please
Please can someone make this for me
Ima go to sleep ill prob be back in 12 hrs
I’ll give it a go.
I know it’s quite far from the original. That petal shape shown in your image stretched my skills. But i gave it a go and completed that which I started. Which is important for me (if nobody esle)?
Let me know if you want it.
Do you know how I can make it
Not sure what you mean. You want instructions on how I did that?
yes I need instructions on how u made it
Ok. See how time go for me this weekend. If i can get some time I’ll do a very rough YouTube video on the process I used. It was a very basic approach that matches my skill level.
Here you go. See whether you can follow it. A bit rough but I tried.
Very Rough Video - Cactus Flower
Thank you so much. I appreciate the help
2 sketches. Top profile and side profile.
Extrude the top profile.
Extrude (choose intersection) the side profile.
Mirror then fillet the bottom edges.
Union the two halves.
Shell the top surfaces.
Use the move tool on the bottom surfaces (as needed) for depth.
Bevel the top inner edge.
Petal
Add flower center to side sketch
Revolve flower center
Trick is planning your model out in as little sketches as needed. To make sure the petals fit I would do my sketch like this first to make sure the assemble petals fit after printed if it is an assembly. Color printing with a single head printer gets better results as an assembly :backhand_index_pointing_down:
Cool Im going to try this approach. I haven’t progressed to using the shell tool and need to give it a go. Thank You
Thank You Oregonerd. I learnt a lot there.
Your approach looked great too. The only thing I would have done extra is blended the top edge of the petals with a fillet where they bend.
