Colors for cross section
Dear Shapr3D Team
When using the cross section view for multiple components, it would be helpful if the cross sections of each part also reflected the body’s color, or a different cross hatch design. I’ve shown an example here where two mating threaded parts interface, but I can’t view the threaded interface, or any indication where the two parts meet.
By being able to view the different components in different colors, will help users identify interferences.
Not having this feature, forces me to toggle back and forth, hiding and unhiding the components. Sometimes creating a projection of each component is required to view the interferences, tolerances, and allowances.
Best regards
McD
On the roadmap, coming next year! :slight_smile:
Istvan, great!
McD
