Copy & Paste measurements , Feature request
I often use measured dimensions as input for the next design step.
At the moment I have to remember the measured value and type it in over the number field.
It would be great one could copy the values (by tapping on the value?) and paste it into the number field.
What do you thing?
Continuing the discussion from Copy & Paste measurements , Feature request:
Copy and paste is actually standard.
This should really work as described by Mbock.
Furthermore, you should also be able to copy the values in the new Measurements tool - otherwise, you have to type out very large numbers and this is always associated with errors.
Thanks for the adjustment in the next update.
István - what do you think about this?
Best regards
Markus
