I got an airplane cockpit in stl format whom I would like to trace cross section curves, using splines, along the airframes longitudinal axis. Using the loft function it should then be a simple task to create a solid surface of the cockpit.
I thought the cross section view would be possible to use but it doesn’t cut the stl file as expected possibly since its not a solid surface but rather a sheet body.
Any suggestion on how this process can be achieved?
