Mike I just wanted to let you know that I was finally able to get the variable fillet into my design but it did take a little bit of thinking on how to do it. What i did was create the variable fillet in a different Cad software and just keep the variable fillet and a little more material on the bottom and outside then save it out as a step file then import that step file into the S3D design then align it in place and do a subtract of the step file part from the S3D design and the fillet came in good. My hope is that in the near future Shapr3D will add Variable fillet options to their fillet command to be able to do this a lot easier.
Thanks for your Help.
