Is it possible to add a variable fillet radius to the Chamfer/filet feature?
-This feature is standard in my others cad programs. In parts and mold design, we use it many times in part design.
-As an example, in (mold)runners design, sometime i need to add a radius along the edge of a runner but cannot keep the same dimension due to material flow so i start with a 2mm radius at the beginning and a 5mm radius at the end. it can grow or decrease linearly or smoothly.
-It’s a useful feature in general design
-This is indeed a barrier in design. This force me to use another program just because of that.
-BUT i like very much where Shapr3D Parametric is now.!!!
I would also like to see this feature included. Every update i check to see if this has been added. It would really transform my creative options. Imagine you wanted to draw a classic snail shell. Currently the radius on a conical spiral can only be as big as what will fit at the small end. A variable radius would allow you to have a radius expanding in proportion to the spiral. Hopefully it can be added soon. Shapr3D on the iPad is my favourite CAD
I would like to see variable fillets also. Additionally limit points on fillets.
It is on our roadmap, likely within the next 3 months,
