Not sure I correctly understand the for of the body from the first image but here some experiments
Run this in terminal:
defaults write com.shapr3d.shapr com.shapr3d.shapr.userDefaults.handedness.isLeftHanded 1
lofting between the pie piece and the triangle face is causing a curve, but id like it to just be straight across. here are some more photos, hopefully they help..
also, i am not sure how to create a sketch on that edge between those two faces like your latest video ![]()
thanks for your help, you’re very resourceful
i need to watch a video on lofting.. i think its helpful when something obscure needs made, and my mind doesnt know when i need to utilize it or how to really. this stuff your showing me is kind of witchcraft atm
Or using Loft:
wow.. ok. this was really educational. thank you so much for setting that up again for me!
